Using GCC and the SoftConsole Eclipse based IDE
Includes a tiny embedded web server with CGI scripting
[Embedded Ethernet Examples]
Microsemi SmartFusion A2F200M3 A2F-EVAL-KIT FPGA and ARM Cortex-M3 microcontroller kit
This page documents a FreeRTOS ARM Cortex-M3 demo application that targets the Microsemi (formally Actel) SmartFusion mixed signal FPGA with integrated ARM Cortex-M3 microcontroller.
FreeRTOS includes ARM Cortex-M3 ports for the GCC, Keil and IAR compilers. Demo application projects targeting the A2F200M3 SmartFusion are provided for the SoftConsole (Eclipse), IAR Embedded Workbench, and Keil MDK IDEs . This page provides instruction on using the GCC / SoftConsole IDE only. A separate page provides instructions on using the IAR and Keil IDEs.
The SoftConsole project is configured to run on the A2F-EVAL-KIT SmartFusion evaluation board.
IMPORTANT! Notes on using the FreeRTOS SoftConsole/Eclipse/GCC SmartFusion Demo Project
The FreeRTOS zip file download contains source code for all the FreeRTOS ports, and every demo application project. It therefore contains many more files than are required to build and run the SmartFusion SoftConsole demo. See the Source Code Organization section for a description of the downloaded files, and information on creating a new project.
The SoftConsole project file for the SmartFusion A2F200M demo is located in the FreeRTOS/Demo/CORTEX_A2F200_SoftConsole directory. This is the project that should be imported into the SoftConsole workspace. The Preparing the Eclipse Project section below contains important information on setting up the demo project directory, and importing the demo project into SoftConsole.
Preparing the SoftConsole (Eclipse) project directory
Eclipse projects can be either standard makefile projects, or managed make projects. The SmartFusion SoftConsole project uses a managed make project. This in turn means that either:
Option 1 is used in this case. To that end, the directory FreeRTOS/Demo/CORTEX_A2F200_SoftConsole contains a batch file called CreateProjectDirectoryStructure.bat that will copy all the required FreeRTOS source files into sub directories inside the demo project directory.
CreateProjectDirectoryStructure.bat must be executed before the SoftConsole project is imported into the Eclipse workspace.
CreateProjectDirectoryStructure.bat cannot be executed from within the SoftConsole Eclipse IDE.
The SoftConsole project contains three build configurations:
The two tasks communicate via a queue - the queue send task, and the queue receive task. The queue receive task toggles an LED each time it receives a value.
Pressing user button SW1 generates an interrupt, the ISR for the interrupt resets a software timer before turning an LED on. The software timer has a five second period, and when the five seconds has expired, the software timer callback function turns the LED off again. Therefore, pressing SW1 will turn the LED on, and the LED will remain on until a full five seconds pass without the button being pressed again.
Further, the Full build configuration creates yet more tasks that are neither part of the Blinky configuration, or the set of standard demo tasks. These additional tasks are described briefly below this table.
Full_with_optimisation The functionality of the Full_with_optimisation build configuration is identical to that of the Full build configuration. Full_with_optimisation has compiler optimisation set high. Full has compiler optimisation off. That is the only difference between the two.
Tasks and timers that are created by both the Full and Full_with_optimisation build configurations, that are not part of either the Blinky demo, or the standard demo tasks, include:
    Each time the check timer expires, its associated callback function queries the status of all the running standard demo tasks. If any queried status is returned as 'failed', then the period of the Check timer is shortened to 500ms, from its original setting of 3 seconds.
    The callback function assigned to the check timer toggles LED D8 each time it executes. Therefore, if LED D8 is toggling every three seconds, then no errors have been reported. If LED D8 is toggling every 500ms, then at least one standard demo task has reported an error. The name of the standard demo task that reported the error can be viewed using the embedded web server - it is displayed at the bottom of the "task stats" web page, under the task stats table.
  • uIP task
  • OLED task
    The OLED task scrolls a message across both of the two OLED rows.
Web server configuration
The demo application includes an embedded web server. The IP address used by the web server is fixed, and set set by the constants configIP_ADDR0 to configIP_ADDR3. The definition of these constants can be found near the bottom of the FreeRTOSConfig.h header file, which is itself located in the same directory as the SoftConsole project file. Constants that define the MAC address, and the NET mask, are located in the same header file.
The IP addresses used by the web server running on the SmartFusion device, and the web browser used to connect to the web server, must be compatible with each other. To ensure this is the case, make the first three octets of both IP addresses the same. For example, if the web browser computer uses IP address 192.168.0.1, then the SmartFusion device can be given any IP address in the range 192.168.0.2 to 192.168.0.254 - other than any IP addresses that is already present on the same network.
This section provides instructions on the hardware set up required to program an application into the ARM Cortex-M3 flash memory. It is assumed that the SmartFusion FPGA fabric and ACE are already configured correctly, which will be the case if the configuration has not been changed from that programmed into the device when the A2F-EVAL-KIT was shipped. However, if the FPGA fabric or ACE configuration has been altered from that shipped, and you find the demo application does not execute correctly, then it is recommended to restore the FPGA fabric and ACE configuration using the .pdb file supplied with the A2F-EVAL-KIT kit.
  1. Ensure jumper JP7 is set to the "USB PROG" position.
  2. Ensure jumper JP10 is set to the "M3" position.
  3. Connect a USB cable from the port marked "J13" and "USB PROG" (that is the same connector) on the A2F-EVAL-KIT board to the computer that is running the SoftConsole IDE. This is the port through which the ARM Cortex-M3 will be programmed.
  4. Use an Ethernet cable to connect the A2F-EVAL-KIT hardware to a computer running a standard web browser. This needs to be done either directly, by using a crossover (point to point) Ethernet cable, or through a hub/switch, using a standard Ethernet cable. Only the direct connection option was tested during development of the demo, but both methods should work.
  5. Connect a USB cable from the port marked "J14 USB/UART" to any USB port that is capable of supplying power. In this demo, J14 is only used as a power supply.
To import the SmartFusion SoftConsole project into an existing or new Eclipse Workspace:
  1. Select "Import" from the SoftConsole "File" menu. The dialogue box shown below will appear.
    The first import dialogue box in the SoftConsole Eclipse IDE
  2. In the next dialogue box, select FreeRTOS/Demo/CORTEX_A2F200_SoftConsole as the root directory. Then, make sure the RTOSDemo project is checked in the "Projects" area, and that the Copy Projects Into Workspace box is not checked, before clicking the Finish button (see the image below for the correct check box states, the finish button is not visible in the image).
    SoftConsole Actel Microsemi Compiler Importing Project
Building and executing the demo application using SoftConsole tools
  4. Select 'Debug Configurations...' from the IDE 'Run' menu.
  5. In the dialogue box that appears, highlight "Microsemi ARM Cortex-M3 eNVM Target" in the tree of targets on the left hand side, then click the "New Launch Configuration" speed button, highlighted in red in the image below.
  6. A new debug configuration will be created that should be named to match the build configuration being used. In the image below, the "Blinky" build configuration was being used.
  7. Ensure the correct application file is being used, highlighted in green in the image below. In this case, because the "Blinky" build configuration was being used, the correct application file is "BlinkyRTOSDemo".
  8. Click the "Debug" button to commence debugging.
    SoftConsole GCC GUI Debug Configuration
Served web Pages
The served IO page
Configuration items specific to this demo are contained in FreeRTOS/Demo/CORTEX_A2F200_SoftConsole/FreeRTOSConfig.h. The constants defined in this file can be edited to suit your application. In particular -
