Renesas RX62N Demo using the IAR Embedded Workbench
Including an embedded web Server with CGI scripting
[Embedded Ethernet Examples]
This page documents the FreeRTOS / IAR port and demo application for the Renesas RX62N. The FreeRTOS download includes demo applications for two standard development boards - the Renesas RX62N Starter Kit (RSK) and the Renesas RX62N Demonstration Kit (RDK) boards.
Demo applications are also available for the GCC and Renesas compilers.
The demo application includes an example web server that uses a modified version of the tiny uIP TCP/IP stack. Code-named FreeTCPIP, the modifications allow for higher throughput than that achievable with the original code. CGI scripting is used to serve pages that include both RTOS and TCP/IP run time information.
uIP was originally written by Adam Dunkels and is open source but licensed separately from FreeRTOS. Users must familiarise themselves with the uIP licence, which is included at the top of each uIP source file.
IMPORTANT! Notes on using the FreeRTOS / IAR / RX62N port and web server demo
The Embedded Workbench workspaces for the RDK and RSK boards are both called RTOSDemo.eww and can be located in the FreeRTOS/Demo/RX600_RX62N-RDK_IAR and FreeRTOS/Demo/RX600_RX62N-RSK_IAR directories respectively of the main FreeRTOS download.
RX62N Demo Application
The Embedded Workbench workspace contains three build configurations:
Blinky This is a very simple example that just creates two tasks. The tasks communicate via a queue, with an LED being toggled each time a correct and expected value is received from the queue. The Blinky build configuration uses main-blinky.c, the other two build configurations use main-full.c.
Debug This is a more comprehensive demo that creates nearly 50 demo tasks. Two further tasks are then repeatedly creates and deleted as the application runs. The tasks consist mainly of the standard demo tasks - which don't perform any particular functionality other than testing the port (including interrupt nesting) and demonstrating how the FreeRTOS API is used. Information on additional tasks that are created is provided immediately below this table.
Debug_with_optimisation This is very similar to the 'Debug' configuration, but includes an additional high frequency timer test. It also tests that the tasks and tests execute correctly when the optimiser is switched on.
  • Check task
    This only executes every five seconds but has the highest priority to ensure it gets CPU time. Its main function is to check that all the standard demo tasks are still operational. The check function writes to a status string that can be viewed at the very bottom of the "Task Stats" page served by the integrated web server. It also toggles LED5 if using the RSK, or LED9 if using the RDK. If the LED controlled by the check task is toggling once every five seconds then all the tasks are executing without any errors having been reported. If the toggle frequency increases to once every 200ms then an error has been detected in at least one task.
  • uIP task
    This is the task that runs the uIP TCP/IP stack. All network related processing is performed in this task, making the TCP/IP Flash and RAM footprint extremely small compared to other embedded TCP/IP implementations.
  • Reg test tasks
    These two tasks fill the microcontroller registers with known values before checking that each register still contains the written value. The two tasks each use different known values. The tasks execute with a very low priority so will get preempted often. If a register ever contains an unexpected value then an error has occurred - probably in the context switching or interrupt mechanism. The reg test tasks write directly into registers and are therefore written in assembly code.
  • High frequency timer test
    This test configures a timer to generate an interrupt at 20KHz. The interrupt priority is above configMAX_SYSCALL_INTERRUPT_PRIORITY so its timing should not be effected by the RTOS kernel. The jitter in the interrupt timing is measured and displayed at the bottom of the "Run Time Stats" page served by the integrated web server.
Web server configuration
  2. If using an RSK development board connect the RSK to the host computer using an E1 JTAG interface (provided as part of the RSK) then apply power. If using an RDK development board just connect the micro USB socket on the RDK that is marked J-Link to the host computer - no separate power is needed.
  3. Open the RTOSDemo.eww workspace from within the Embedded Workbench IDE.
  4. Select "Build All" from the Embedded Workbench "Project" menu - the demo application should build without errors.
  5. When the build completes click "Download and Debug" from the Embedded Workbench "Project" menu (or press CTRL+D) to program the microcontroller flash memory and start a debug session.
Served web Pages
The served IO page
Configuration items specific to this demo are contained in FreeRTOS/Demo/RX600_RX62N-RSK_IAR/FreeRTOSConfig.h or FreeRTOS/Demo/RX600_RX62N-RDK_IAR/FreeRTOSConfig.h for the RSK and RDK hardware respectively. The constants defined in these file can be edited to suit your application. In particular -
Interrupts can be written using the standard IAR compiler syntax. For example, the demo application defines the high frequency timer using:
#pragma vector = VECT_CMT2_CMI2
__interrupt void vTimer2IntHandler( void )
    the demo so interrupts are just left disabled while the function executes. */
    __enable_interrupt();
FreeRTOS requires exclusive use of the software interrupt. FreeRTOS also requires exclusive use of a timer that can generate a periodic tick interrupt - but it is up to the application writer to define which timer is used. To do this the application must define a function called vApplicationSetupTimerInterrupt() that configures the tick interrupt using the chosen peripheral, then define configTICK_VECTOR to inform the RTOS kernel of the interrupt vector number of the chosen timer.
It is suggested that a compare match timer is used to generate the tick interrupt, and an example implementation of vApplicationSetupTimerInterrupt() that uses compare match timer 0 is included in both main-full.c and main-blinky.c within the demo application. The demo application defines configTICK_VECTOR within FreeRTOSConfig.h to be 28 (VECT_CMT0_CMI0 - the compare match 0 interrupt vector number). It is suggested that the provided example implementations are used in most cases.
