RTOS Stream & Message Buffers
Stream buffers are an RTOS task to RTOS task, and interrupt to task communication primitives. Unlike most other FreeRTOS communications primitives, they are optimised for single reader single writer scenarios, such as passing data from an interrupt service routine to a task, or from one microcontroller core to another on dual core CPUs. Data is passed by copy - the data is copied into the buffer by the sender and out of the buffer by the read.
Stream buffers pass a continuous stream of bytes. Message buffers pass variable sized but discrete messages. Message buffers use stream buffers for data transfer.
Further Reading
The following pages describe stream buffers and message buffers in more detail, and provide examples of their use to implement interrupt to task and processor core to processor core communications respectively.
More about Stream Buffers...
More about Message Buffers...
Blog on using message buffers for core to core communication...
