SOFTWARE
FreeRTOS for AWS IoT
FreeRTOS for AWS libraries implement clients for AWS IoT specific value add cloud services, including over the air updates (OTA). These libraries are suitable for building smart microcontroller-based devices that connect to the AWS IoT cloud. Like the FreeRTOS core libraries, they have no dependencies on anything other than the standard C library, so are not dependent on the FreeRTOS RTOS kernel.
See all library categories.
Libraries
AWS IoT OTA
Source code is now available in the AWS IoT Over-the-air Update github repository.
Learn More
AWS IoT Device Shadow
Source code is now available in the AWS IoT Device Shadow github repository.
Learn More
AWS IoT Jobs
Source code is now available in the AWS IoT Jobs github repository.
Learn More
AWS IoT Device Defender
Source code is now available as an independent repository in the AWS IoT Device Defender github repository.
Learn More
AWS IoT Fleet Provisioning
Source code is now available as an independent repository in the AWS IoT Fleet Provisioning github repository.
Learn More
AWS Signature Version 4
Generate a signature and authorization header that complies with the AWS Signature Version 4 signing process.
Source code is now available as an independent repository in the AWS Signature Version 4 github repository.
Learn More
Reference Integrations
AWS Quick Connect
Quick Connect demos make it simple to setup and connect a partner provided, FreeRTOS qualified board to AWS IoT, all in the space of a few minutes. These demos can be used for non-production applications to explore the IoT space.
For more information, refer to AWS Quick Connect Demos page.
AWS Reference Integrations
AWS Reference Integrations are pre-integrated FreeRTOS projects ported to microcontroller-based evaluation boards that demonstrate end to end connectivity to the cloud. AWS Reference Integrations help save months of development effort and accelerate time to market.
Source code is now available in the AWS Reference Integration github repository.
Learn More
