FreeRTOS LTS Libraries
AWS also offers the FreeRTOS Extended Maintenance Plan (EMP) that provides you with security patches and critical
bug fixes on your chosen FreeRTOS LTS version for up to an additional 10 years. Visit the
FreeRTOS webpage on
AWS for details.
The 202012.01 FreeRTOS LTS release covers the following libraries: FreeRTOS kernel, FreeRTOS+TCP, coreMQTT, coreHTTP, corePKCS11, coreJSON, AWS IoT Device Shadow, AWS IoT OTA, AWS IoT Jobs, AWS IoT Device Defender, and AWS IoT Fleet Provisioning. Subsequent releases starting from 202012.02 version provides LTS patches for security and critical bug fixes.
Note:This download contains source code for just the latest FreeRTOS 202012 Long Term Support (LTS) libraries, with no build projects of examples. The primary FreeRTOS download contains example projects. Refer to the FAQ for details.
FreeRTOS LTS libraries are also available from partner toolchains. See the blog post.
LTS Status
The following table lists the libraries that are part of the FreeRTOS 202012 LTS release. All meet the LTS modularity and Code Quality Checklist requirements other than the kernel and TCP stack, both of which still comply with their original quality requirements.
Last Updated: 12/20/2021
Library |
Version |
Maintained at least until |
FreeRTOS Kernel |
10.4.3-LTS-Patch-2 |
March 31, 2023 |
FreeRTOS+TCP |
2.3.2-LTS-Patch-2 |
March 31, 2023 |
coreMQTT |
1.1.0 |
March 31, 2023 |
coreHTTP |
2.0.0 |
March 31, 2023 |
corePKCS11 |
3.0.0 |
March 31, 2023 |
coreJSON |
3.0.0 |
March 31, 2023 |
AWS IoT Device Shadow |
1.0.2 |
March 31, 2023 |
AWS IoT OTA |
3.0.0 |
March 31, 2023 |
AWS IoT Jobs |
1.1.0 |
March 31, 2023 |
AWS IoT Device Defender |
1.1.0 |
March 31, 2023 |
AWS IoT Fleet Provisioning |
1.0.1 |
March 31, 2023 |
FreeRTOS LTS Patches
For the latest information, subscribe to Github Notifications by watching the FreeRTOS LTS repository. For the complete list of updates for each patch, view the Changelog.
Patch Version |
Updates |
Post |
202012.04 LTS |
Includes critical bug fixes for the FreeRTOS-Plus-TCP library (2.3.2-LTS-Patch-2). |
Release notes |
202012.03 LTS |
Includes security patches for the FreeRTOS kernel (10.4.3-LTS-Patch-2). |
Security Updates |
202012.02 LTS |
Includes security patches for the FreeRTOS kernel (10.4.3-LTS-Patch-1) and TCP libraries (V2.3.2-LTS-Patch-1). |
Security Updates |
202012.01 LTS |
Added AWS IoT OTA, AWS Device Defender, and AWS IoT Jobs library to 202012.00 LTS |
Blog Post |
LTS Code Quality Checklist
Category |
Checks |
1 |
Complexity Score |
Functions shall have a GNU Complexity score less than 8. |
2 |
Coding Standard |
Functions shall comply with the MISRA 2012 coding standard. |
3 |
Static Checking |
Functions shall pass Coverity static checking. |
4 |
APSEC review and pentest |
Libraries must pass AWS security review. |
5 |
Code Testing, including memory safety proofs |
All code shall have extensive unit and function tests, with Gcov reports detailing test coverage,
as well as CBMC memory safety proofs. |
6 |
Requirements Documentation |
All libraries shall have documented requirements, which may include resource, dependency, and porting requirements (as applicable). |
7 |
Design Documentation |
All libraries shall have design documentation, including application and cloud interface, state machines, and synchronization (as applicable). |
8 |
Compiler Warning |
The code shall compile with GCC using the -Wall and -Wextra command line options without generating compiler warnings. |
