SOFTWARE
Transport Interface
Custom Implementations
Applications can provide their own implementation of the Transport Interface if the example implementations don't match the underlying network or TLS stack. An implementation has two parts. The first is the definition of a network context data structure that wraps an underlying data stream, such as a socket handle or a TLS context. The second is a pair of functions that can send and receive data on that network context - these two functions just wrap whichever network send and receive functions you are already using within functions that have the prototype expected by the transport interface structure. There is a worked example below. The Transport Interface structure is defined as follows:
* The NetworkContext is an incomplete type. An implementation of this
* interface must define struct NetworkContext for the system's requirements.
* For example, a plain-text implemention of the NetworkContext type might
* include a socket, and a TLS implementation might add a TLS context. This
* context is passed into the network interface send() and recv() functions.
struct NetworkContext;
* @brief Transport interface for receiving data on the network.
* @note It is RECOMMENDED that the transport receive implementation
* does NOT block when requested to read a single byte. A single byte
* read request can be made by the caller to check whether there is a
* new frame available on the network for reading.
* However, the receive implementation MAY block for a timeout period when
* it is requested to read more than 1 byte. This is because once the caller
* is aware that a new frame is available to read on the network, then
* the likelihood of reading more than one byte over the network becomes high.
* @param[in, out] pNetworkContext Implementation-defined network context.
* @param[in, out] pBuffer Buffer to receive the data into.
* @param[in] bytesToRecv Number of bytes requested from the network.
* @return The number of bytes received or a negative value to indicate
* error.
* @note If no data is available on the network to read and no error
* has occurred, zero MUST be the return value. A zero return value
* SHOULD represent that the read operation can be retried by calling
* the API function. Zero MUST NOT be returned if a network disconnection
* has occurred.
void * pBuffer,
size_t bytesToRecv );
* @brief Transport interface for sending data over the network.
* @note It is RECOMMENDED that a non-fatal failure in transmitting bytes over
* the network, like a full transmit buffer of the underlying TCP stack, is
* treated as a retriable error operation by returning a zero return value.
* @param[in] pBuffer Buffer containing the bytes to send over the network.
* @param[in] bytesToSend Number of bytes to send over the network.
* @return The number of bytes sent or a negative value to indicate error.
* @note If no data is transmitted over the network and no network error
* has occurred, this MUST return zero as the return value.
* A zero return value SHOULD represent that the send operation can be retried
* by calling the API function. Zero MUST NOT be returned if a network
* disconnection has occurred.
const void * pBuffer,
size_t bytesToSend );
TransportRecv_t recv; /* Receive function (see above) */
TransportSend_t send; /* Send function (see above) */
NetworkContext_t * pNetworkContext; /* Network context (see above) */
} TransportInterface_t;
Transport Interface Structure
Worked Example
This example describes how to create a transport interface for the FreeRTOS+TCP stack (this is for demonstration purposes only as the FreeRTOS source code download already contains a transport interface for FreeRTOS+TCP). For simplicity the example is using TCP without TLS or other form of encryption. Production IoT devices should always use encrypted connections and the FreeRTOS download includes transport interfaces that use FreeRTOS+TCP with TLS stacks.
Starting point
FreeRTOS+TCP sockets are stored in variables of type Socket_t. So the NetworkContext structure can be defined as:
/* The network context just contains the FreeRTOS+TCP socket
* (Note: production systems should use TLS, not just the underlying
* socket, so could use the TLS context here instead of the socket) */
Socket_t tcpSocket;
Defining a NetworkContext structure that just contains a FreeRTOS+TCP socket.
Next, the FreeRTOS+TCP send and receive functions need to be wrapped by functions that have the prototype expected by the transport interface's send and receive functions. The example below also demonstrates how to obtain the socket used by the send and receive functions from the NetworkContext parameter:
/* The prototypes of the following send and receive functions match that
expected by the transport interface's function pointers. These simple
implementations show how to use the network context structure defined
above. */
void * pBuffer,
int32_t socketStatus = 1;
/* The TCP socket may have a receive block time. If bytesToRecv is greater
* than 1, then a frame is likely already part way through reception and
* blocking to wait for the desired number of bytes to be available is the
* most efficient thing to do. If bytesToRecv is 1, then this may be a
* speculative call to read to find the start of a new frame, in which case
* blocking is not desirable as it could block an entire protocol agent
* task for the duration of the read block time and therefore negatively
* impact performance. So if bytesToRecv is 1, then don't call recv unless
* it is known that bytes are already available. */
if( bytesToRecv == 1 )
if( socketStatus > 0 )
return socketStatus;
int32_t socketStatus;
/* The TCP buffers could not accept any more bytes so zero bytes were sent.
* This is not necessarily an error that should cause a disconnect unless
* it persists so return 0 bytes received rather than an error. */
socketStatus = 0;
Implementing the transport send and receive functions for FreeRTOS+TCP
/* Populating the TransportInterface_t structure with the definitions above. */
Example Implementations
The transport interface implementations included in the FreeRTOS download are split into two files - a wrapper C file specific to the TCP stack, and a supplemental C file specific to using a TLS stack with the selected TCP stack. For example, to use FreeRTOS+TCP with mbedTLS, build sockets_wrapper.c from the network_transport/freertos_plus_tcp directory in the source code distribution, then build using_mbedtls.c from the using_mbedtls subdirectory.
