vMessageBufferDelete()
[RTOS Message Buffer API]
message_buffer.h
void vMessageBufferDelete( MessageBufferHandle_t xMessageBuffer );
Deletes a message buffer that was previously created using a call to xMessageBufferCreate() or xMessageBufferCreateStatic(). If the message buffer was created using dynamic memory (that is, by xMessageBufferCreate()), then the allocated memory is freed.
A message buffer handle must not be used after the message buffer has been deleted.
xMessageBuffer   The handle of the message buffer to be deleted.
