queue.h
void vQueueUnregisterQueue( QueueHandle_t xQueue );
Removes a queue from the queue registry.
- Parameters:
xQueue | The handle of the queue being removed from the registry. |
The queue registry has two purposes, both of which are associated with RTOS kernel aware debugging:
- It allows a textual name to be associated with a queue for easy queue identification within a debugging GUI.
- It contains the information required by a debugger to locate each registered queue and semaphore.
The queue registry has no purpose unless you are using a RTOS kernel aware debugger.
configQUEUE_REGISTRY_SIZE defines the maximum number of queues and semaphores that can be registered.
Only the queues and semaphores that you want to view using a RTOS kernel aware debugger need to be registered.
Example:
void vAFunction( void )
QueueHandle_t xQueue;
xQueue = xQueueCreate( 10, sizeof( char ) );
vQueueAddToRegistry( xQueue, "AMeaningfulName" );
vQueueUnregisterQueue( xQueue );
vQueueDelete( xQueue );
