xSemaphoreCreateMutexStatic
[Semaphores]
semphr. h
SemaphoreHandle_t xSemaphoreCreateMutexStatic(
                            StaticSemaphore_t *pxMutexBuffer );
Creates a mutex, and returns a handle by which the created mutex can be referenced. Mutexes cannot be used in interrupt service routines.
configSUPPORT_STATIC_ALLOCATION and configUSE_MUTEXES must both be set to 1 in FreeRTOSConfig.h for xSemaphoreCreateMutexStatic() to be available.
Each mutex require a small amount of RAM that is used to hold the mutex's state. If a mutex is created using xSemaphoreCreateMutex() then the required RAM is automatically allocated from the FreeRTOS heap. If a mutex is created using xSemaphoreCreateMutexStatic() then the RAM is provided by the application writer, which requires an additional parameter, but allows the RAM to be statically allocated at compile time. See the Static Vs Dynamic allocation page for more information.
Mutexes are taken using xSemaphoreTake(), and given using xSemaphoreGive(). xSemaphoreTakeRecursive() and xSemaphoreGiveRecursive() can only be used on mutexes created using xSemaphoreCreateResursiveMutex().
Mutexes and binary semaphores are very similar but have some subtle differences: Mutexes include a priority inheritance mechanism, binary semaphores do not. This makes binary semaphores the better choice for implementing synchronisation (between tasks or between tasks and an interrupt), and mutexes the better choice for implementing simple mutual exclusion.
The priority of a task that 'takes' a mutex will be temporarily raised if another task of higher priority attempts to obtain the same mutex. The task that owns the mutex 'inherits' the priority of the task attempting to 'take' the same mutex. This means the mutex must always be 'given' back - otherwise the higher priority task will never be able to obtain the mutex, and the lower priority task will never 'disinherit' the priority.
An example of a mutex being used to implement mutual exclusion is provided on the xSemaphoreTake() documentation page.
A binary semaphore need not be given back once obtained, so task synchronisation can be implemented by one task/interrupt continuously 'giving' the semaphore while another continuously 'takes' the semaphore. This is demonstrated by the sample code on the xSemaphoreGiveFromISR() documentation page. Note that the same functionality can be achieved in a more efficient way using a direct to task notification.
Handles to both mutexes and binary semaphores are assigned to variables of type SemaphoreHandle_t, and can be used in any task level (as opposed to interrupt safe) API function that takes a parameter of that type.
pxMutexBuffer   Must point to a variable of type StaticSemaphore_t, which will be used to hold the mutex type semaphore's state.
Return:
If the mutex type semaphore was created successfully then a handle to the created mutex is returned. If the mutex was not created because pxMutexBuffer was NULL then NULL is returned.
    /* Create a mutex semaphore without using any dynamic memory
    allocation.  The mutex's data structures will be saved into
    the xMutexBuffer variable. */
    xSemaphore = xSemaphoreCreateMutexStatic( &xMutexBuffer );
    handle will not be NULL. */
    configASSERT( xSemaphore );
