stream_buffer.h
StreamBufferHandle_t xStreamBufferCreateStatic(
size_t xBufferSizeBytes,
size_t xTriggerLevelBytes,
uint8_t *pucStreamBufferStorageArea,
StaticStreamBuffer_t *pxStaticStreamBuffer );
Creates a new stream buffer using statically allocated memory. See
xStreamBufferCreate() for a version that
uses dynamically allocated memory.
must be set to 1 in FreeRTOSConfig.h for xStreamBufferCreateStatic() to be available.
source file in the build.
xBufferSizeBytes
The size, in bytes, of the buffer pointed to by the
pucStreamBufferStorageArea parameter.
xTriggerLevelBytes
The number of bytes that must be in the stream
buffer before a task that is blocked on the stream buffer to wait for data is
moved out of the blocked state. For example, if a task is blocked on a read
of an empty stream buffer that has a trigger level of 1 then the task will be
unblocked when a single byte is written to the buffer or the task's block
time expires. As another example, if a task is blocked on a read of an empty
stream buffer that has a trigger level of 10 then the task will not be
unblocked until the stream buffer contains at least 10 bytes or the task's
block time expires. If a reading task's block time expires before the
trigger level is reached then the task will still receive however many bytes
are actually available. Setting a trigger level of 0 will result in a
trigger level of 1 being used. It is not valid to specify a trigger level
that is greater than the buffer size.
Must point to a uint8_t array that is at least
xBufferSizeBytes + 1 big. This is the array to which streams
are copied when they are written to the stream buffer.
Must point to a variable of type StaticStreamBuffer_t, which
will be used to hold the stream buffer's data structure.
If the stream buffer is created successfully then a handle to the
created stream buffer is returned. If either pucStreamBufferStorageArea or
pxStaticstreamBuffer are NULL then NULL is returned.
/* Used to dimension the array used to hold the streams. The available space
will actually be one less than this, so 999. */
/* Defines the memory that will actually hold the streams within the stream
buffer. */
static uint8_t ucBufferStorage[ STORAGE_SIZE_BYTES ];
/* The variable used to hold the stream buffer structure. */
StaticStreamBuffer_t xStreamBufferStruct;
void MyFunction( void )
const size_t xTriggerLevel = 1;
xStreamBuffer = xStreamBufferCreateStatic( sizeof( ucBufferStorage ),
xTriggerLevel,
ucBufferStorage,
&xStreamBufferStruct );
/* As neither the pucStreamBufferStorageArea or pxStaticStreamBuffer
parameters were NULL, xStreamBuffer will not be NULL, and can be used to
reference the created stream buffer in other stream buffer API calls. */
/* Other code that uses the stream buffer can go here. */
