xTaskCreateRestrictedStatic
[FreeRTOS-MPU Specific]
task. h
BaseType_t xTaskCreateRestrictedStatic( TaskParameters_t *pxTaskDefinition,
Create a new Memory Protection Unit (MPU) restricted task and add it to the list of tasks that are ready to run. configSUPPORT_STATIC_ALLOCATION must be set to 1 in FreeRTOSConfig.h for this RTOS API function to be available.
Internally, within the FreeRTOS implementation, each task requires two blocks of memory. The first block is used to hold the task's data structures. The second block is used as the task's stack. If a task is created using xTaskCreateRestricted() then the memory for the task's stack is provided by the application writer, and the memory for the task's data structures is automatically allocated from the FreeRTOS heap. If a task is created using xTaskCreateRestrictedStatic() then the application writer must provide the memory for the task's data structures too. xTaskCreateRestrictedStatic() therefore allows a memory protected task to be created without using any dynamic memory allocation.
xTaskCreateRestrictedStatic() is intended for use with FreeRTOS-MPU, the demo applications which contain comprehensive and documented examples of how to use the similar function, xTaskCreateRestricted().
pxTaskDefinition  Pointer to a structure that defines the task. The structure is described on this page.
Tasks that include MPU support require even more parameters to create than those that don't. Passing each parameter to xTaskCreateRestrictedStatic() individually would be unwieldy so instead the structure TaskParameters_t is used to allow the parameters to be configured statically at compile time. The structure is defined in task.h as:
    TaskFunction_t pvTaskCode;
    unsigned short usStackDepth;
    void *pvParameters;
    UBaseType_t uxPriority;
    #if ( ( portUSING_MPU_WRAPPERS == 1 ) && ( configSUPPORT_STATIC_ALLOCATION == 1 ) )
        StaticTask_t * const pxTaskBuffer;
    #endif
} TaskParameters_t;
typedef struct xMEMORY_REGION
    void *pvBaseAddress;
    unsigned long ulParameters;
} MemoryRegion_t;
  • pvTaskCode to uxPriority
    These members are exactly the same as the parameters of the same name sent to xTaskCreate(). In particular uxPriority is used to set both the priority of the task and the mode in which the task will execute. For example, to create a User mode task at priority 2, simply set uxPriority to 2, to create a Privileged mode task at priority 2 set uxPriority to ( 2 | portPRIVILEGE_BIT ).
  • puxStackBuffer
    Each time a task is switched in, the MPU is dynamically re-configured to define a region that provides the task read and write access to its own stack. MPU regions must meet a number of constraints - in particular, the size and alignment of all such regions must be equal to the same power of two value.
    Standard FreeRTOS ports use pvPortMalloc() to allocate a new stack each time a task is created. Providing a pvPortMalloc() implementation that took care of the MPU data alignment requirements would be possible but would also be complex and inefficient in its RAM usage. To remove the need for this complexity FreeRTOS-MPU allows stacks to be declared statically at compile time. This allows the alignment to be managed using compiler extensions and RAM usage efficiency to be managed by the linker. For example, if using GCC, a stack could be declared and correctly aligned using the following code:
    puxStackBuffer would normally be set to the address of the statically declared stack. As an alternative puxStackBuffer can be set to NULL - in which case pvPortMallocAligned() will be called to allocate the task stack and it is the application writer's responsibility to provide an implementation of pvPortMallocAligned() that meets the alignment requirements of the MPU.
  • xRegions
        portMPU_REGION_READ_WRITE
        portMPU_REGION_READ_ONLY
        portMPU_REGION_EXECUTE_NEVER
  • pxTaskBuffer
    Must point to a variable of type StaticTask_t. The variable will be used to hold the new task's data structures, so it must be persistent (not declared on the stack of a function).
/* Create an TaskParameters_t structure that defines the task to be created.
 * The StaticTask_t variable is only included in the structure when
 * configSUPPORT_STATIC_ALLOCATION is set to 1.  The PRIVILEGED_DATA macro can
 * be used to force the variable into the RTOS kernel's privileged data area. */
static PRIVILEGED_DATA StaticTask_t xTaskBuffer;
static const TaskParameters_t xCheckTaskParameters =
  vATask,     /* pvTaskCode - the function that implements the task. */
  "ATask",    /* pcName - just a text name for the task to assist debugging. */
  100,        /* usStackDepth - the stack size DEFINED IN WORDS. */
  NULL,       /* pvParameters - passed into the task function as the function parameters. */
  ( 1UL | portPRIVILEGE_BIT ),/* uxPriority - task priority, set the portPRIVILEGE_BIT
                                   if the task should run in a privileged state. */
  cStackBuffer,/* puxStackBuffer - the buffer to be used as the task stack. */
  /* xRegions - Allocate up to three separate memory regions for access by
   * the task, with appropriate access permissions.  Different processors have
   * different memory alignment requirements - refer to the FreeRTOS documentation
   * for full information. */
      /* Base address                 Length  Parameters */
      { cReadWriteArray,              32,     portMPU_REGION_READ_WRITE },
      { cReadOnlyArray,               32,     portMPU_REGION_READ_ONLY },
      { cPrivilegedOnlyAccessArray,   128,    portMPU_REGION_PRIVILEGED_READ_WRITE }
  &xTaskBuffer; /* Holds the task's data structure. */
 int main( void )
 TaskHandle_t xHandle;
  /* Create a task from the const structure defined above.  The task handle
   * is requested (the second parameter is not NULL) but in this case just for
   * demonstration purposes as its not actually used. */
  xTaskCreateRestricted( &xRegTest1Parameters, &xHandle );
  /* Start the scheduler. */
  vTaskStartScheduler();
  /* Will only get here if there was insufficient memory to create the idle
   * and/or timer task. */
  for( ;; );
