message_buffer.h
BaseType_t xMessageBufferGetStaticBuffers( MessageBufferHandle_t xMessageBuffer,
uint8_t ** ppucMessageBufferStorageArea,
StaticMessageBuffer_t ** ppxStaticMessageBuffer );
configSUPPORT_STATIC_ALLOCATION must be defined as 1 for this function to be available. See the RTOS Configuration
documentation for more information.
Retrieve pointers to a statically created message buffer's data structure buffer and storage area buffer. These are the same buffers that are
supplied at the time of creation.
xMessageBuffer
The message buffer whose data structure buffer and storage area buffer will be retrieved.
Used to return a pointer to the message buffer's storage area buffer.
Used to return a pointer to the message buffer's data structure buffer.
